I’ve started with the SparkFun OpenLog.
It was flashing twice at the time to start with and after I’ve formatead the SD card has fixed it .
I see it has also created the CONFIG.TXT file with the default settings.
Following the instruction, I see the are different configurations to add on and/or change in Config file?, and in our case, we’d like to record the GPS data connected to the RX pin.
What is the change required within the Config to read this RX data and store it in the SD card?
Many thanks and apologies if I’ve missed it in the instructions
