Now I’ve defined the following packed struct.
MBED_PACKED(struct) Feedback
public:
unsigned char motorID;
float position;
float velocity;
float current;
When I pass the member variable of Feedback object as a reference to a function and access the reference in the function, hard fault exception happens like below.
Feedback feedback;
unsigned char a[8];
ParameterRange r;
toParameter(a, r, feedback.motorID, feedback.position);
void toParameter(unsigned char (&data)[8], ParameterRange &range, unsigned char &canID, float &position)
int p_int = (data[1] << 8) | data[2];
int v_int = (data[3] << 4) | (data[4] >> 4);
int t_int = (data[4] & 0xf) << 8 | data[5];
canID = data[0];
float span = range.positionRange.max - range.positionRange.min;
float offset = range.positionRange.min;
position = (int) ((p_int)*((float)((1<<16)-1))/span); <-- at this point, hard fault exception happens
If I write the Feedback class without packing option or I pass a float type local variable in the caller stack as a reference or pass the feedback object as a reference to access the member variable such as feedback.position, the exception doesn’t happen.
My system is Mbed 6.8.0 and NUCLEO-F767ZI.
Here is the crash log:
- MbedOS Fault Handler –
++ MbedOS Error Info ++
Error Value: 0x200001F8
Current Thread: main Id: 0x20005A70 Entry: 0x8009691 StackSize: 0x1000 StackMem: 0x200044D0 SP: 0x20005458
For more info, visit: https://mbed.com/s/error?error=0x80FF013D&tgt=NUCLEO_F767ZI
– MbedOS Error Info –
= Reboot count(=19) reached maximum, system will halt after rebooting =
++ MbedOS Fault Handler ++
FaultType: HardFault
Context:
R 0: 00000000
R 1: 20005484
R 2: 2000546C
R 3: 2000546D
R 4: 200054AC
R 5: 2000547C
R 6: 20005460
R 7: 2000546D
R 8: 20005484
R 9: 2000546C
R 10: 00000000
R 11: 00000000
R 12: 00000000
SP : 20005460
LR : 08008913
PC : 080043DC
xPSR : 21000000
PSP : 200053F8
MSP : 2007FFD0
CPUID: 411FC270
HFSR : 40000000
MMFSR: 00000000
BFSR : 00000000
UFSR : 00000100
DFSR : 00000000
AFSR : 00000000
Mode : Thread
Priv : Privileged
Stack: PSP
– MbedOS Fault Handler –
Current Thread: main Id: 0x20005A70 Entry: 0x8009691 StackSize: 0x1000 StackMem: 0x200044D0 SP: 0x20005460
= Reboot count(=20) reached maximum, system will halt after rebooting =
