I am trying to send data to thingspeak.com.
I am using mbedTLS for https, but in the handshake steps client hello is not working it returns following logs,
Socket opened successfully.
SSL state connect : 0 . Performing the SSL/TLS handshake...../Middlewares/Third_Party/mbedTLS/library/ssl_tls.c:6571: => handshake
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:3363: client state: 0
../Middlewares/Third_Party/mbedTLS/library/ssl_tls.c:2417: => flush output
../Middlewares/Third_Party/mbedTLS/library/ssl_tls.c:2429: <= flush output
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:3363: client state: 1
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:0719: => write client hello
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:0757: client hello, max version: [3:3]
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:0766: dumping 'client hello, random bytes' (32 bytes)
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:0766: 0000: da 62 ed 2f dc 6e 08 0f 87 cd 66 a6 32 30 21 c0 .b./.n....f.20!.
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:0766: 0010: 1b e2 e1 83 47 e9 b6 de 24 53 5e e3 b0 d1 39 35 ....G...$S^...95
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:0819: client hello, session id len.: 0
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:0820: dumping 'client hello, session id' (0 bytes)
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:0887: client hello, add ciphersuite: c02c
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:0887: client hello, add ciphersuite: c030
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:0887: client hello, add ciphersuite: c0ad
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:0887: client hello, add ciphersuite: c0af
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:0887: client hello, add ciphersuite: c02b
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:0887: client hello, add ciphersuite: c02f
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:0887: client hello, add ciphersuite: c0ac
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:0887: client hello, add ciphersuite: c0ae
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:0887: client hello, add ciphersuite: 009d
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:0887: client hello, add ciphersuite: c09d
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:0887: client hello, add ciphersuite: c0a1
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:0887: client hello, add ciphersuite: 009c
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:0887: client hello, add ciphersuite: c09c
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:0887: client hello, add ciphersuite: c0a0
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:0920: client hello, got 15 ciphersuites
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:0951: client hello, compress len.: 1
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:0953: client hello, compress alg.: 0
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:0072: client hello, adding server name extension: api.thingspeak.com
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:0178: client hello, adding signature_algorithms extension
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:0263: client hello, adding supported_elliptic_curves extension
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:0328: client hello, adding supported_point_formats extension
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:0544: client hello, adding extended_master_secret extension
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:0577: client hello, adding session ticket extension
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:1025: client hello, total extension length: 91
../Middlewares/Third_Party/mbedTLS/library/ssl_tls.c:2702: => write record
../Middlewares/Third_Party/mbedTLS/library/ssl_tls.c:2839: output record: msgtype = 22, version = [3:1], msglen = 166
../Middlewares/Third_Party/mbedTLS/library/ssl_tls.c:2842: dumping 'output record sent to network' (171 bytes)
../Middlewares/Third_Party/mbedTLS/library/ssl_tls.c:2842: 0000: 16 03 01 00 a6 01 00 00 a2 03 03 da 62 ed 2f dc ............b./.
../Middlewares/Third_Party/mbedTLS/library/ssl_tls.c:2842: 0010: 6e 08 0f 87 cd 66 a6 32 30 21 c0 1b e2 e1 83 47 n....f.20!.....G
../Middlewares/Third_Party/mbedTLS/library/ssl_tls.c:2842: 0020: e9 b6 de 24 53 5e e3 b0 d1 39 35 00 00 1e c0 2c ...$S^...95....,
../Middlewares/Third_Party/mbedTLS/library/ssl_tls.c:2842: 0030: c0 30 c0 ad c0 af c0 2b c0 2f c0 ac c0 ae 00 9d .0.....+./......
../Middlewares/Third_Party/mbedTLS/library/ssl_tls.c:2842: 0040: c0 9d c0 a1 00 9c c0 9c c0 a0 00 ff 01 00 00 5b ...............[
../Middlewares/Third_Party/mbedTLS/library/ssl_tls.c:2842: 0050: 00 00 00 17 00 15 00 00 12 61 70 69 2e 74 68 69 .........api.thi
../Middlewares/Third_Party/mbedTLS/library/ssl_tls.c:2842: 0060: 6e 67 73 70 65 61 6b 2e 63 6f 6d 00 0d 00 12 00 ngspeak.com.....
../Middlewares/Third_Party/mbedTLS/library/ssl_tls.c:2842: 0070: 10 06 03 06 01 05 03 05 01 04 03 04 01 03 03 03 ................
../Middlewares/Third_Party/mbedTLS/library/ssl_tls.c:2842: 0080: 01 00 0a 00 18 00 16 00 19 00 1c 00 18 00 1b 00 ................
../Middlewares/Third_Party/mbedTLS/library/ssl_tls.c:2842: 0090: 17 00 16 00 1a 00 15 00 14 00 13 00 12 00 0b 00 ................
../Middlewares/Third_Party/mbedTLS/library/ssl_tls.c:2842: 00a0: 02 01 00 00 17 00 00 00 23 00 00 ........#..
../Middlewares/Third_Party/mbedTLS/library/ssl_tls.c:2436: message length: 171, out_left: 171
../Middlewares/Third_Party/mbedTLS/library/ssl_tls.c:2442: ssl->f_send() returned -30848 (-0x7880)
../Middlewares/Third_Party/mbedTLS/library/ssl_tls.c:2847: mbedtls_ssl_flush_output() returned -30848 (-0x7880)
../Middlewares/Third_Party/mbedTLS/library/ssl_cli.c:1047: mbedtls_ssl_write_record() returned -30848 (-0x7880)
../Middlewares/Third_Party/mbedTLS/library/ssl_tls.c:6582: <= handshake
failed
! mbedtls_ssl_handshake returned -0x7880
Failed closing the socket.
../Middlewares/Third_Party/mbedTLS/library/ssl_tls.c:7359: => free
../Middlewares/Third_Party/mbedTLS/library/ssl_tls.c:7424: <= free
I am able to use HTTP get and send data, but the problem comes in the handshake when I use mbedTLS.
whether I can send raw hex values using CIPSEND? or I had to use any other characters?
