I am working on a PPPoS connection between PC and a custom embedded board using RS485. For the direction pin, I’ve tried various solutions, all of which seem suboptimal:
- Custom wrapper around BufferedSerial that sets the direction pin and resets it after a delay after writing. This made me able to send data once, then receive data infinitely, but none of the incoming data made it past pppos_input (see information below).
- Custom wrapper around UnbufferedSerial that sets the direction pin and resets it when receiving a TX empty interrupt (I did not implement sigio here, so this caused ppp_service to never start reading).
- Make a copy of entire BufferedSerial class and add direction pin functionality. This had the same result as the first option.
I tried to search for RS485 drivers for mbed OS, which I found, but all of them either 1) failed to use the direction pin or 2) made use of mbed OS 2 and its deprecated Serial API.
Anyway, with option 1 I can successfully send an LCP ConfReq and receive the corresponding ConfAck, but the input is never passed to ppp_input. I can see the packets are successfully obtained (albeit in bursted chunks), see the following debug logging (I patched it to print out the data, since PRINTPKT_SUPPORT does not work for mbed OS).
ppp phase changed[0]: phase=0
ppp_connect[0]: holdoff=0
ppp phase changed[0]: phase=3
pppos_connect: unit 0: connecting
ppp_start[0]
ppp phase changed[0]: phase=6
pppos_send_config[0]: out_accm=FF FF FF FF
ppp_send_config[0]
pppos_recv_config[0]: in_accm=FF FF FF FF
ppp_recv_config[0]
pppos_write[0]: len=24
ppp_start[0]: finished
pppos_input[0]: got 11 bytes:
7e ff 7d 23 c0 21 7d 21 7d 21 7d
pppos_input[0]: got 16 bytes:
20 7d 34 7d 22 7d 26 7d 20 7d 20 7d 20 7d 20 7d
25 7d 26 2b 91 64 49 7d 27 7d 22 7d 28 7d 22 e9
pppos_input[0]: got 2 bytes:
ab 7e
When I went on to debug this issue, I found that pppos.cpp :: pppos_input performs the following code:
if (ppp_call_callback(ppp->netif->service_ptr, pppos_input_callback, inp) != ERR_OK) {
I have verified that this code is executed, and ppp_call_callback returns ERR_OK.
However, the actual callback function never seems to be called (pppos_input_callback).
I’m new to mbed OS and not familliar with this callback functionality, and I can’t find information on how to debug this kind of issue. Perhaps you kind folk can point me in the right direction?
