I am getting following error while I run ‘yotta build’ command. I am trying to install mbed client on Raspberry Pi. I am following this tutorial mbed client linux example
Error:
info: generate for target: x86-linux-native 1.0.0 at /home/pi/mbed-client-linux-example/yotta_targets/x86-linux-native
– The C compiler identification is GNU 4.6.3
– The CXX compiler identification is GNU 4.6.3
– Check for working C compiler using: Ninja
– Check for working C compiler using: Ninja – broken
CMake Error at /usr/local/share/cmake-3.2/Modules/CMakeTestCCompiler.cmake:61 (message):
The C compiler “/usr/bin/cc” is not able to compile a simple test program.
It fails with the following output:
Change Dir: /home/pi/mbed-client-linux-example/build/x86-linux-native/CMakeFiles/CMakeTmp
Run Build Command:“/usr/bin/ninja” “cmTryCompileExec1896237997”
/usr/bin/ninja: 1: /usr/bin/ninja: Syntax error: “)” unexpected
CMake will not be able to correctly generate this project.
Call Stack (most recent call first):
CMakeLists.txt:65 (project)
– Configuring incomplete, errors occurred!
See also “/home/pi/mbed-client-linux-example/build/x86-linux- native/CMakeFiles/CMakeOutput.log”.
See also “/home/pi/mbed-client-linux-example/build/x86-linux-native/CMakeFiles/CMakeError.log”.
error: command [‘cmake’, ‘-D’, ‘CMAKE_BUILD_TYPE=RelWithDebInfo’, ‘-G’, ‘Ninja’, ‘.’
