Hello everybody,
I am working on an embedded project and I’m just getting into learning about unit tests, I have written some before and they appear to detect that the case fails, however, the overall test is considered as passed. I am working on a NUCLEO-F722ZE and below is an example of the code I am running:
void testSimpleFailure(void) {
TEST_FAIL_MESSAGE("This test should fail");
UNITY_BEGIN();
RUN_TEST(testSimpleFailure);
return UNITY_END();
and here is an example of the output:
.\main.cpp:108:testSimpleFailure:FAIL: This test should fail
.\main.cpp:113:testSimpleFailure:PASS
1 Tests 0 Failures 0 Ignored
OK
The output does not seem to quite align with what I am expecting. Any advice is appreciated.
Thanks in advanced.
