Uvisor+LCD=program stops working, on STM32f429 discovery
I’m a beginner using mbed OS and Embedded programing in general, i want to become familiar with mbed OS and uvisor and my aim is to use the LCD screen to print or not the secret in the secured box.
so when i juste use mbed-library with uvisor disabled, everything works perfectly. But when i try to enable uvisor library, my program stops working. I’ve tried implementing a simple example using mbed OS+uvisor and it works well. I hope you can help me, thank you in advance.
Here is my code :
main.cpp:
#include "mbed-drivers/mbed.h"
#include "minar/minar.h"
#include "core-util/FunctionPointer.h"
#include "uvisor-lib/uvisor-lib.h"
#include "lcd.h"
#include "main.h"
#include "btn.h"
/* messages on LCD */
char uvisorhello[] = " *** uvisor-Hello ***";
using mbed::util::FunctionPointer0;
/* Create ACLs for main box. */
MAIN_ACL(g_main_acl);
/* Enable uVisor. */
UVISOR_SET_MODE_ACL(UVISOR_ENABLED, g_main_acl);
DigitalOut led(MAIN_LED);
DigitalOut red_led(RED_LED);
void toggle_led()
  led = !led;
void init_periph()
  /* Init LCD */
  init_LCD();
  /* Configure the pushbutton. */
  btn_init();
void main_prog()
  toggle_led();
void app_start(int, char**){
    init_periph();
    lcd_print(uvisorhello);
    minar::Scheduler::postCallback(toggle_led).period(minar::milliseconds(1500));
main.h:
void  lcd_print(char *str);
void lcd_clear();
void toggle_led();
#define LED_ON  true
#define LED_OFF false
#define MAIN_LED LED1
#define RED_LED LED2
#define MAIN_BTN USER_BUTTON
#define MAIN_BTN_PD PullDown
#define MAIN_ACL(acl_list_name)                           \
    static const UvisorBoxAclItem acl_list_name[] = {     \
        {TIM2,   sizeof(*TIM2),   UVISOR_TACLDEF_PERIPH}, \
        {TIM5,   sizeof(*TIM5),   UVISOR_TACLDEF_PERIPH}, \
        {GPIOA,  sizeof(*GPIOA),  UVISOR_TACLDEF_PERIPH}, \
        {GPIOG,  sizeof(*GPIOG),  UVISOR_TACLDEF_PERIPH}, \
        {GPIOC, sizeof(*GPIOC), UVISOR_TACLDEF_PERIPH}, \
        {GPIOD, sizeof(*GPIOD), UVISOR_TACLDEF_PERIPH}, \
        {GPIOF, sizeof(*GPIOF), UVISOR_TACLDEF_PERIPH}, \
        {SPI5, sizeof(*SPI5), UVISOR_TACLDEF_PERIPH}, \
        /* FIXME: Secure RCC/EXTI/SYSCFG/FLASH */         \
        {RCC,    sizeof(*RCC),    UVISOR_TACLDEF_PERIPH}, \
        {EXTI,   sizeof(*EXTI),   UVISOR_TACLDEF_PERIPH}, \
        {SYSCFG, sizeof(*SYSCFG), UVISOR_TACLDEF_PERIPH}, \
        {FLASH,  sizeof(*FLASH),  UVISOR_TACLDEF_PERIPH}, \
        {PWR,    sizeof(*PWR),    UVISOR_TACLDEF_PERIPH}, \
        {(void *) 0x42470000, 0x1000, UVISOR_TACLDEF_PERIPH}, \
lcd.cpp :
  #include "lcd.h"
/* Font size structure */
TM_FONT_SIZE_t FontSize;
void init_LCD()
  /* Init LCD */
  TM_LCD_Init();
  /* Fill LCD with color */
  //TM_LCD_Fill(0x4321);
  /* Verify if the bottom of the screen is reached*/
  if(TM_LCD_GetCurrentY()>TM_LCD_GetHeight())  lcd_clear();
  /* Put string to LCD */
  TM_LCD_Puts(str);
void lcd_clear()
  TM_LCD_SetXY(0,0);
  TM_LCD_Fill(0xFFFF);
lcd.h :
#include "lib/stm32fxxx_hal.h"
#include "lib/tm_stm32_disco.h"
#include "lib/tm_stm32_delay.h"
#include "lib/tm_stm32_lcd.h"
#include "main.h"
void init_LCD();
void lcd_clear();
I think the problem comes from the ACL in main.h, there is no recognized LCD periphery name, so i add its register address manually
For the moment my ACL looks like :
        {(void *) 0x40020000, 0x2BFF, UVISOR_TACLDEF_PERIPH}, \
        {DMA2D, sizeof(*DMA2D), UVISOR_TACLDEF_PERIPH}, \
        {DMA2, sizeof(*DMA2), UVISOR_TACLDEF_PERIPH}, \
        {(void *) 0x40016800, 0x3FF, UVISOR_TACLDEF_PERIPH}, \
        {SAI1, sizeof(*SAI1), UVISOR_TACLDEF_PERIPH}, \
        {I2C3, sizeof(*I2C3), UVISOR_TACLDEF_PERIPH}, \
still doesn’t work. :confused:
I have a question about this line :
i took it from helloworld example and it’s related to reserved memory in memory mapping. I don’t really understand why it is so important to add it in the ACL.
Do you have reserved it?
