Are smart pointers full implemented in Mbed OS?
Does anyone know if there are any limitations with using Smart Pointers in C++ in Mbed OS?
I happened to try the following code snippet:
    std::shared_ptr<int[]> arr = std::shared_ptr<int[]>(new int[20]);
    arr[0] = 0;
This won’t compile in Mbed Studio, but does in Linux (g++ and Clang, C++ 11 onwards).
which compiler are you using in Mbed Studio?
See my answer here: Embedded, Mbed OS & Smart pointers - #5 by ladislas
The default - ARM C6
Hi @noutram,
Any chance you could provide:
  • Any specific output/errors from the toolchain
  • The compile (command line) options being passed to AC6
Carey - Studio Team
[Error] main.cpp@7,34: no matching conversion for functional-style cast from 'int *' to 'std::shared_ptr<int []>' [Error] main.cpp@8,8: type 'std::shared_ptr<int []>' does not provide a subscript operator [ERROR] .\main.cpp:7:34: error: no matching conversion for functional-style cast from 'int *' to 'std::shared_ptr<int []>' std::shared_ptr<int[]> arr = std::shared_ptr<int[]>(new int[20]);
In the mbed library, Tools/profiles/debug.json, I can see the following:
"ARMC6": { "common": ["-c", "--target=arm-arm-none-eabi", "-mthumb", "-g", "-O1", "-Wno-armcc-pragma-push-pop", "-Wno-armcc-pragma-anon-unions", "-Wno-reserved-user-defined-literal", "-Wno-deprecated-register", "-DMULADDC_CANNOT_USE_R7", "-fdata-sections", "-fno-exceptions", "-MMD", "-fshort-enums", "-fshort-wchar", "-DMBED_DEBUG", "-DMBED_TRAP_ERRORS_ENABLED=1"], "asm": [], "c": ["-D__ASSERT_MSG", "-std=gnu11"], "cxx": ["-fno-rtti", "-fno-c++-static-destructors", "-std=gnu++14"], "ld": ["--verbose", "--remove", "--show_full_path", "--legacyalign", "--any_contingency", "--keep=os_cb_sections"] },
Thank you @noutram.
Sorry for the late reply, I had to seek some clarification with another team. shared_ptr to array isn’t supported until C++17, which Arm Compiler 6 only provides as a COMMUNITY feature currently: Documentation – Arm Developer
But passing std=c++17 should allow your code above to compile.
I’m not sure why GCC appears to be backwards compatible with this.
Best,
Carey - Studio Team
Hi
Thanks - that is really useful to know. In fact, having read the link you provide, I am inclined to add
-Wpedantic to make it clearer to students. In this context, risk management is more important than new language features for sure!
Nick
I’m curious what you mean about “risk management” in this context :slight_smile:
Good question. Maybe a better expression is “defensive coding”.
If developing software to run unsupervised 24/7, maybe sticking to the language version Arm recommend rather than leaping for newer and greater. Presumably mbed os has a QA process, and this is done using c++14.
