I am having FRDM K64f board with ethernet Connectivity. but i dont want to use Ethernet.
I am using external ESP 8266 wifi chip, it is connected successfully to internet, i got IP address.
I am able to run legacy example code for mbed cloud connect, it is also connected to mbed device connector.
You’ll want to make sure you update your Wi-Fi hotspot information in the correct .json file and then compile using the following command: mbed compile --app-config configs/wifi_esp8266_v4.json
