I wonder if it is possible to disable the UART attached to mbed-trace once it is enabled in mbed_app.json. I couldn’t find a way to do it in run-time.
To what I understand:
- The target implements the HAL functionality of the serial object (using the external variable
stdio_uart_initedit reports if the UART was initialized correctly) - Based on mbed_app.json we either use
BufferedSerialorDirectSerialclass which use the target-implementation initialization in the constructor. - In mbed_retarget.cpp we create the console object from either
BufferedSerialorDirectSerial(both of them inheritsSerialBaseclass the one it really uses the HAL functions).
I can’t see further how we can deinitialize.
What makes me more confidence that serial_free from targets implementation is called only with the private method _deinit in SerialBase. _deinit is called with enable_input(false).
