I’m trying to record the time from falling edge to the rising edge of RX pin with time capture, I tried using interrupt triggers but the implementation would always fail. Currently i found this but i am not sure how to attach it to falling and rising edge of a digital input. TimerCapture | Mbed
Is there any way i could implement this library to record the timing of a falling edge to a rising edge, within around 400us? Thank you
Here is my code so far, but apparently it always detect multiple interrupt trigger as i have a set of 7 falling and 7 rising edges. I wonder is there any better way?
Timer high;
Timer low;
InterruptIn RECV(D6);
int times;
void fall_irq(){
high.start();
void rise_irq(){
high.stop();
times = high.read_us();
printf("%i ", times);
high.reset();
RECV.fall(&fall_irq);
RECV.rise(&rise_irq);
Also i notice that this code takes up 8 values and then only to be able to be printed per 8 values of “times” i wonder what did i do wrong .
I will add…
The printf is not allowedin IRQ because of mutex but not in old versions of MbedOS (5.12 or lower) or Mbed 2. Anyway using printf in IRQ is not good practice because that function is slow.
Change the variable int time to volatile int time and let read it in while loop.
I do not know what a board do you use but the library what you posted above was designed for LPC1768.
This code uses TIMER2 on the LPC1768. I have no idea if it will work on other hardware, but I hope it helps someone else!
Thank you, i tried printf on the main loop, but it won’t print anything, any idea why this occur? I assume that the while loop should be written in the main? I will post my attempt soon, thank you
Thank you, it worked nicely, would it be available to call the interrupt inside one of the interrupts?
Also i’m trying to capture the times since the logic looks like this ––––––– which has multiple times, quite not sure why it doesn’t work.
* Copyright (c) 2021 ARM Limited
using namespace std::chrono;
DigitalOut led(LED1);
Timer high;
Timer low;
volatile int times;
volatile int lows;
InterruptIn RECV(D7);
void fall_irq(void);
void rise_irq(void);
void fall_end_irq(void);
void rise_end_irq(void);
int i = 0;
void fall_irq(){
low.start();
RECV.rise(&fall_end_irq);
void fall_end_irq(){
low.stop();
lows = duration_cast<microseconds>(high.elapsed_time()).count();
low.stop();
void rise_irq(){
high.start();
RECV.fall(&rise_end_irq);
void rise_end_irq(){
high.stop();
times = duration_cast<microseconds>(high.elapsed_time()).count();
high.reset();
//Trigger everytime sees low and high
int bits[16];
int i = 0;
while (true) {
if(times != 0){
printf("time capture: %d us\n", times);
bits[i] = times;
i++;
times = 0;
if(lows != 0){
printf("time capture: %d us\n", lows);
bits[i] = lows;
i++;
lows = 0;
if(i > 16){
i = 0;
for(int j=0; j < 16; j++)
printf("%d ",bits[i]);
bits[i] = 0;
