on my custom board, I used an custom target to tell mbed to use HSE xtal as clock source. This stopped to work after I upgraded to mbed 6.10.
The old config:
(yes I made the device compatibile with nucleo_l152 because defining a whole new target is pain for me)
This worked well with mbed 6.8 and I was able to measure the crystal loop oscillating at 16mhz.
However, after upgrading mbed to latest version (6.10), the board completely freezes after uploading the FW. No mbed error happens and sometimes (with no regularity) it lights up the signal LED indefinitely. No error code, nothing. But the scope shows nice smooth 16Mhz sine on the crystal.
Then I found the updated docs and replaced the old clock configuration with this (snipped from the docs):
"clock_src": {
"help": "Clock source to use, can be XTAL or RC",
"value": "XTAL"
"clock_freq": {
"help": "Clock frequency in Mhz",
"value": "16",
"macro_name": "CLOCK_FREQUENCY_MHZ"
The board works fine again - BUT - the oscillator is not oscillating and PLL on HSI16 is used as clock source.
I tried to override these settings, but it says that clock_src does not exist in the parent definition.
What exactly has been changed and how can I change the clock properly now?
The system clock for your board is configured in the mbed-os/targets/TARGET_STM/TARGET_STM32L1/TARGET_STM32L152xE/system_clock.c file:
* SPDX-License-Identifier: BSD-3-Clause
* Copyright (c) 2016-2020 STMicroelectronics.
* All rights reserved.
* This software component is licensed by ST under BSD 3-Clause license,
* the "License"; You may not use this file except in compliance with the
* License. You may obtain a copy of the License at:
* opensource.org/licenses/BSD-3-Clause
* This file configures the system clock as follows:
* System clock source | 1- USE_PLL_HSE_EXTC (external 8 MHz clock)
* | 2- USE_PLL_HSE_XTAL (external 8 MHz xtal)
* | 3- USE_PLL_HSI (internal 16 MHz)
* SYSCLK(MHz) | 32
* AHBCLK (MHz) | 32
* APB1CLK (MHz) | 32
* USB capable | YES
#include "stm32l1xx.h"
#include "mbed_error.h"
#define USE_PLL_HSE_EXTC 0x8 // Use external clock (ST Link MCO)
#define USE_PLL_HSE_XTAL 0x4 // Use external xtal (X3 on board - not provided by default)
#define USE_PLL_HSI 0x2 // Use HSI internal clock
#if ( ((CLOCK_SOURCE) & USE_PLL_HSE_XTAL) || ((CLOCK_SOURCE) & USE_PLL_HSE_EXTC) )
uint8_t SetSysClock_PLL_HSE(uint8_t bypass);
#endif /* ((CLOCK_SOURCE) & USE_PLL_HSE_XTAL) || ((CLOCK_SOURCE) & USE_PLL_HSE_EXTC) */
#if ((CLOCK_SOURCE) & USE_PLL_HSI)
uint8_t SetSysClock_PLL_HSI(void);
#endif /* ((CLOCK_SOURCE) & USE_PLL_HSI) */
MBED_WEAK void SetSysClock(void)
#if ((CLOCK_SOURCE) & USE_PLL_HSE_EXTC)
/* 1- Try to start with HSE and external clock */
if (SetSysClock_PLL_HSE(1) == 0)
#endif
#if ((CLOCK_SOURCE) & USE_PLL_HSE_XTAL)
/* 2- If fail try to start with HSE and external xtal */
if (SetSysClock_PLL_HSE(0) == 0)
#endif
/* 3- If fail start with HSI clock */
if (SetSysClock_PLL_HSI() == 0)
#endif
error("SetSysClock failed\n");
/* Output clock on MCO1 pin(PA8) for debugging purpose */
//HAL_RCC_MCOConfig(RCC_MCO1, RCC_MCO1SOURCE_SYSCLK, RCC_MCODIV_1);
/* PLL (clocked by HSE) used as System clock source */
MBED_WEAK uint8_t SetSysClock_PLL_HSE(uint8_t bypass)
RCC_ClkInitTypeDef RCC_ClkInitStruct;
RCC_OscInitTypeDef RCC_OscInitStruct;
/* Used to gain time after DeepSleep in case HSI is used */
if (__HAL_RCC_GET_FLAG(RCC_FLAG_HSIRDY) != RESET) {
return 0;
/* The voltage scaling allows optimizing the power consumption when the device is
clocked below the maximum system frequency, to update the voltage scaling value
regarding system frequency refer to product datasheet. */
__PWR_CLK_ENABLE();
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
/* Enable HSE oscillator and activate PLL with HSE as source */
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
if (bypass == 0) {
RCC_OscInitStruct.HSEState = RCC_HSE_ON; /* External 8 MHz xtal on OSC_IN/OSC_OUT */
} else {
RCC_OscInitStruct.HSEState = RCC_HSE_BYPASS; /* External 8 MHz clock on OSC_IN */
RCC_OscInitStruct.HSIState = RCC_HSI_OFF;
// SYSCLK = 32 MHz (8 MHz *12 /3)
// USBCLK = 48 MHz (8 MHz *12 /2)
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL12;
RCC_OscInitStruct.PLL.PLLDIV = RCC_PLL_DIV3;
if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK) {
return 0; // FAIL
/* Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2 clocks dividers */
RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2);
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK; // 32 MHz
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1; // 32 MHz
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1; // 32 MHz
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1; // 32 MHz
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK) {
return 0; // FAIL
//if (bypass == 0)
//HAL_RCC_MCOConfig(RCC_MCO1, RCC_MCO1SOURCE_HSE, RCC_MCODIV_2); // 4 MHz
//else
//HAL_RCC_MCOConfig(RCC_MCO1, RCC_MCO1SOURCE_HSE, RCC_MCODIV_1); // 8 MHz
return 1; // OK
/* PLL (clocked by HSI) used as System clock source */
__PWR_CLK_ENABLE();
/* Enable HSI oscillator and activate PLL with HSI as source */
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
RCC_OscInitStruct.HSEState = RCC_HSE_OFF;
RCC_OscInitStruct.HSIState = RCC_HSI_ON;
RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
// SYSCLK = 32 MHz (16 MHz *6 /3)
// USBCLK = 48 MHz (16 MHz *6 /2)
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL6;
return 0; // FAIL
/* Poll VOSF bit of in PWR_CSR. Wait until it is reset to 0 */
while (__HAL_PWR_GET_FLAG(PWR_FLAG_VOS) != RESET) {};
return 0; // FAIL
//HAL_RCC_MCOConfig(RCC_MCO1, RCC_MCO1SOURCE_HSI, RCC_MCODIV_1); // 16 MHz
return 1; // OK
As you can see the frequency of the external crystal supposed to be 8 MHz (rather than 16 MHz).
Since the settings of the PLL dividers an multipliers don’t seem to be adjusted by taking into account the HSE_VALUE macro I’m afraid only an 8 MHz crystal can be used as external clock source.
So I would suggest to use the old custom board configuration file but omitting the “config” section and to install an 8 MHz external crystal rather than a 16 MHz one:
Hi Zoltan,
thanks for your reply. I’ll probably stick with the 8Mhz crystal then. But I’m still wondering how come it worked before…Well, a best guess is I had changed the PLL multiplier manually to 6 someday and then forgot about it…
Anyway, what about the documentation here? There is an example inside showing clock config that I posted above:
"clock_src": {
"value": "XTAL"
"clock_freq": {
"value": "16",
I get that for my current target there is no option how to adjust the multipliers from the json. But what about the new naming here? So is this just dummy example and it does nothing in real? Or it just does not work with this current target? I don’t get it. Either way it is quite misleading.
I fully agree, the examples for adding and configuring targets should be more exact. For example, in case of the config and overrides it should be explained that the defined macros are not available yet in the mbed source code but supposed to be fully implemented by the user.
I had removed the external XTRAL from the NCULEO-L432KC board,
and I got the same problem , when I use the “USE_PLL_HSI” , and mbed 6.12 return below run-time error info:
++ MbedOS Error Info ++
Error Value: 0x0
Current Thread: Id: 0x0 Entry: 0x8000299 StackSize: 0x0 StackMem: 0x8000325 SP: 0x2000FE4C
– MbedOS Error Info –
HAL_RCC_OscConfig ERROR
