yes, it is possible. It can depend on some steps how did you create/import your project. First what you can try is to close and reopen MbedStudio or re-select your project, but if the issue persist then try to delete BUILD folder in your project.
I often use the F767ZI with MbedStudio, so it is working.
Similar issue
“mbed.h” not found because of BUILD folder - Mbed Studio / Bugs - Arm Mbed OS support forum
BTW if you have an issue with the MbedStudio try to put topic to section for MbedStudio and not MbedOS.
