Hello everyone,
We’re designing a new product using the STM32L151ZE microcontroller. We’ve been doing some tests with the NUCLEO-L152RE dev board and everything has been good so far. Now, we want to move on to the final microprocessor and we realized that it is not present in the device list. I would like to know what are the steps to “create” my own board device in the mbed OS file system so we can stil use all the libraries and developments made so far.
Many thanks for your time. Best regards,
Manuel
Pekka01
(Pekka Saavalainen)
December 20, 2019, 12:06pm
2
Hi Manuel,
To be able to do and maintain official supported board you have to be a Partner. You can still use your own board.
You can fork, customize and build DAPLink for your purposes. We have mechanisms to let developers to detect their custom platform using the mbed ls mock feature for their development:
# Development moved
The development of Mbed LS has been moved into the [mbed-os-tools](../../src/mbed_os_tools) package. You can continue to use this module for legacy reasons, however all further development should be continued in the new package.
[](https://badge.fury.io/py/mbed-ls)
# Mbed LS
Mbed LS is a Python (2 and 3) module that detects and lists Mbed Enabled devices connected to the host computer. The Mbed OS team publishes Mbed LS on PyPI. It works on all major operating systems (Windows, Linux and Mac OS X).
It provides the following information for all connected boards in a console (terminal) output:
- Mbed OS platform name.
- Mount point (MSD or disk).
- Serial port.
# Installation
This file has been truncated. show original
You can also create configuration for a custom platform:
# Using Mbed OS on a custom board
When designing a custom microcontroller board to run Mbed OS, you may need to
make software customizations for the unique design choices you have made for
your new board, such as clocking, pin connections and peripheral use. You can
accomplish this by adding configuration and source files to an Mbed OS-based
application project without the need to modify files within Mbed OS, itself.
You can add a file named `custom_targets.json` to your project, which can store
your custom target configurations. If your board is based on an existing Mbed
Enabled microcontroller, you can simply extend that board configuration without
the need to implement all the files yourself.
This tutorial covers the most common methods used to create a custom port of
Mbed OS when starting from an existing Mbed Enabled board. For detailed
information on how to create a port from scratch, go to the [Mbed Porting
guide](../porting/index.html). Additionally, not all possible aspects of target
configuration are covered. For detailed information on all the ways you can
configure targets, go to [adding and configuring
targets](../program-setup/adding-and-configuring-targets.html).
Pekka
LMESTM
(Laurent Meunier)
December 20, 2019, 12:08pm
3
And for the specifics about adding support for a new board based on STM32 please visit:
https://os.mbed.com/teams/ST/wiki/steps-to-create-a-new-STM32-platform
