MbedStudio - Serial Monitor
Ahoj,
The serial monitor in the Mbed Studio was a good choice I think but there is a lack of some options.
  • Enable/Disable auto open the serial monitor. When the Mbed Studio is running the monitor is auto opened directly after a USB cable of any board is plugged, It doesn’t matter if the board sends something or not. Also it does not wait for confirmation form the msgbox “Mbed Studio: Set device as active?”. Also when you connect more than one board the window is opened for each one.
  • An option for clear the window. The window can be clear only via close and reopen the window.
  • A Input line for opposite direction of serial communication
Is in a plan add additional functionality into Serial Monitor?
Ahoj Jan,
We are glad you like it and thank you for the feedback. Yes, it is an initial implementation of this feature. We are planning improvements. More details below:
  • We wanted to make it as simple as possible. That’s why a serial monitor is automatically open when the board is connected. Baudrate selection is also saved for a given board. I like the suggestion about the msgbox confirmation (Mbed Studio has a similar option to change active target when a new board is connected). We will think about adding it also to a serial feature.
  • A separate window for each board is not a bug. We decided to support serial input/output from many boards at the same time. There is a separate window for each of them as each connection may use different serial options (for example baudrate).
  • Yes. We are thinking about implementing 2 new buttons. One for clearing the window (similar to the one already existing in the terminal panel). Second for saving output in the file.
  • The opposite direction is already implemented. It is present in Mbed Studio 0.7.0 and 0.8.0 on both platforms. The UI for it is not obvious at the moment but every character you type in serial window is automatically sent to the device. You can test it by adding getc() in your code. We are planning to improve it in the future and allow to send multiple characters at once.
  • Closing the serial panel for a given board is releasing it. A serial monitor outside of Mbed Studio can be used then.
  • We are working on updating documentation: Introduction - Introduction to Mbed OS 6 | Mbed OS 6 Documentation. Please expect the serial feature to be documented soon.
Arek - Mbed Studio team
Hi Jan,
Documentation is updated now with latest changes. Including serial monitor: Using the Mbed Studio Serial Monitor view - Monitoring and debugging | Mbed Studio Documentation.
