Seeed WM1110 support
Hallo, is it known if there are plans to include Seeed’s WM1110 module in the supported boards list? Best regards, Axel
unfortunately no, but it is know there are no plans for the future about anything from Arm side because development was stopped few years ago.
Targets are usually added by manufacturers but this also will not happen probably.
I see two options but both are in your hands:
  1. With regular Mbed it seems to be possible to add it manually like a custom target because the MCU is supported - TARGET_MCU_NRF52840 but this lora interface not. However, there were an attempt lora driver-Added LR1110 driver in mbed-os by kvkc97 · Pull Request #14560 · ARMmbed/mbed-os (github.com)
  2. We are working with a fork of MbedOS called MbedCE - Home · mbed-ce/mbed-os Wiki (github.com). However it is little bit different and if the online build tool is important then MbedCE is not for you.
