Hi Romas,
It is a very good question. You can find build output in Output tab. By default it should be available in the bottom panel (Problems tab should also be there by default). In case you closed it you can bring it back by going into: Menu->View->Output. Please take a look also into a dropdown on Output widget. Depending on context it provides different information.
Thanks,
Arek - Mbed Studio team
