Today Showing Error (Previously Working this code on 31.5.25)
Today Only these Kind of error Came .
Build started
Using toolchain ARM_STD profile {‘ENV’: {‘ARMLMD_LICENSE_FILE’: ‘8224@10.100.182.21:8224@10.100.106.178’}, ‘PATHS’: {‘ARMC6_PATH’: ‘/opt/ARMCompiler6.15.13/bin/’, ‘ARM_PATH’: ‘/opt/armcc5_06_u6/’}, ‘common’: [‘-c’, ‘–gnu’, ‘-O3’, ‘-Otime’, ‘–split_sections’, ‘–apcs=interwork’], ‘cxx’: [‘–cpp’, ‘–no_rtti’], ‘COMPILE_C_AS_CPP’: False, ‘NEW_SCAN_RESOURCES’: True}
scan /tmp/chroots/ch-922b122a-6e4d-4194-9ec6-f3dbc74fca45/src
scan /tmp/chroots/ch-922b122a-6e4d-4194-9ec6-f3dbc74fca45/extras/mbed-os.lib
Configuration error: ‘static_memory_defines’ is not defined.
429 Too Many Requests<429 Too Many Requests
< nginx< 429 Too Many Requests<429 Too Many Requests
< nginx<
compile IBT2/IBT2.cpp
Warning: C9564I: Retrying - Mon Jun 2 07:15:18 2025
Warning: C9564I: Retrying - Mon Jun 2 07:15:19 2025
Warning: C9564I: Retrying - Mon Jun 2 07:15:20 2025
Warning: C9564I: Retrying - Mon Jun 2 07:15:21 2025
Error: C9555E: Failed to check out a license.
Unable to connect to the license server. Check that ARMLMD_LICENSE_FILE is set correctly, and the license server is available.
Information about this error is available at: All Support Services
General licensing information is available at: All Support Services
If you need further help, provide this complete error report to your supplier or license.support@arm.com.
- ARMLMD_LICENSE_FILE: ‘8224@10.100.182.21:8224@10.100.106.178’
- LM_LICENSE_FILE: unset
- ARM_TOOL_VARIANT: unset
- ARM_PRODUCT_PATH: unset
- Product location: /opt/armcc5_06_u6/sw/mappings
- Toolchain location: /opt/armcc5_06_u6/bin
- Selected tool variant: product
- Checkout feature: compiler5
- Feature version: 5.0201709
- Flex error code: -15
Product: ARM Compiler 5.06
Component: ARM Compiler 5.06 update 6 (build 750)
Tool: armcc [4d3637]
Internal error.
Build failed
Build failed
