I have been developing code on ST’s Nucleo- L476 board based system. I use a desktop and laptop since 2021 and mostly using mbed-os - ver 5.0
Recently I wanted to cretae mbed studio IDE in a laptop running Windows 10 so I installed installername: MbedStudio-1.4.3.exe . Next I copied whole workspace from desktop in laptop.
When I opened IDE and workspace, I could see all files correctly. When I pressed Build button, I got a series of error messages, whose summary was Failed to check out a license. the full error message is pasted at the end of this post.
Please help me to get ver 5.0 I am using some of teh old version verbs such as wait() or class Serial that are not supported in ver 6.xx
error message:
Building project mbed-os-example-blinky-5 (NUCLEO_L476RG, ARMC6)
Scan: mbed-os-example-blinky-5
Compile [ 0.1%]: AC.cpp
[ERROR] armclang: error: Failed to check out a license.
The license has expired.
armclang: note:
Information about this error is available at: All Support Services
General licensing information is available at: All Support Services
If you need further help, provide this complete error report to your supplier or license.support@arm.com.
I was able to open Libraries card and using add Mbed Library, managed to download OS ver 5.15.3-rc1^2. I used check out method to remove existing ver 6 and download ver 5.15.I hope whole of ver has been removed from workspace.
When I built program, it still gives a similar error. It still shows ARM 6.15 compiler being used. the error message is as follows:
armclang: note:
You can ignore this, it doesn’t have anything together with MbedOS version. However the installation contains also approx one year licence (date limited not from installation) for Arm Compiler 6 which is not free in normal way. And that lead us to the root cause because latest version seems to be 1.4.6 - Installing Mbed Studio - Installing | Mbed Studio Documentation.
