UBLOX_C027" is not recognized
Hello all,
I updated my mbed-os library to new mbed-os 5 library, because it has the new versuin of the LWIP library but I faced this issue:
Error: Target “UBLOX_C027” is not recognized
Ublox-C-027 is not supported in the new mbed-os???
Please help
Nada
Ublox targets are not supported in the MbedOS6+, latest version where was your target supported is MbedOS5.15.5.
You can verify that here. You will not found combination of MbedOS 6 and Ublox targets.
Thank you Johnny for your help.
I want to ask you if I can import this version directly or I have to go back to the old revision.?
and If I have to do so, could you please tell me which one?
Thank you in advance.
Nada
Hello Nada,
I do not know what tool you use but for the Oline compiler
Thank you Johny for your support.
I really appreciete it
Dear Johnny,
How can I change in the mbed os library files
Everytime I tried to open one file, I faced this error: documentation path not found. I tried to export the program to my laptop and change the file but when I want again to upload the file to the online compiler, I’m facing an error: zip file empty.
How can I change the files in the library online?
How can I change any file online
Hello Nada,
The tree what you see on your picture is only Doxygen documentation. And I am sure that is not possible with Online compiler directly.
Hi Johnny,
Thank you so much for your quick reply and support. I managed to do my changes. I already import the new version and then switch to mbed os 5.15.6 version.
But I want to ask you a question please, Do you have any idea how to activate the Vlan on mbed. I know that I have to assign 1 to ETHARP_SUPPORT_VLAN 1 inOPt.h file
  • ETHARP_SUPPORT_VLAN==1: support receiving and sending ethernet packets with
  • VLAN header. See the description of LWIP_HOOK_VLAN_CHECK and
  • LWIP_HOOK_VLAN_SET hooks to check/set VLAN headers.
  • Additionally, you can define ETHARP_VLAN_CHECK to an u16_t VLAN ID to check.
  • If ETHARP_VLAN_CHECK is defined, only VLAN-traffic for this VLAN is accepted.
  • If ETHARP_VLAN_CHECK is not defined, all traffic is accepted.
  • Alternatively, define a function/define ETHARP_VLAN_CHECK_FN(eth_hdr, vlan)
  • that returns 1 to accept a packet or 0 to drop a packet.
but how can I handle the other callbacks
  • LWIP_HOOK_VLAN_SET hooks .
I’m trying for weeks and I didn’t find many information mentioned about that.
If you have any idea or any example I will be apprecieted even if it’s whith the LPC1768.
Nada
Hi Nada,
I would like to help but I don’t know anything about that, sorry.
Thank you so much Johnny, You helped me alot.
Nada
