Upload Problems, NUCLEO-H743ZI2
When I try uploading to my board, LED3 flashes red frequently. My upload does not happen, and when I try to manually drip the .bin file, I get an error that the board does not have enough space. Has anyone encountered this or know the solution to this?
Thank you,
Frank
Check this old topic -Not enough space on NUCLEO-WB55RG
Br, Jan
Hello @JohnnyK ,
My Jumper is in the STLINK position but I am still having the same problem.
Thank you,
Frank
There were several topics around this issue in the past, but always with different solution, how I remember.
Options:
  • update ST-link firmware and ST-Link drivers
  • no solution found, user identified the board is broken, but I have no info about how it was broken
  • bad settings of jumpers - I also face that, because I change settings for external power supply.
Just for sure try take a multimeter and check if main MCU is correctly powered.
