On the Pelion Device Management platform, my device is not listed in the device directory.
I am using DHCP and can ping my device. When using the TLS example application the connection to a HTTPS website works. When i look on my SD card all KV store files are present.
I tried to reconfig the certificates but it still doesn’t work.
Can you please specify which board are you using? Further, try to see if this workaround described here from a recently reported issue, can fix the problem you are facing.
I am using a custom made board. It uses the STM32F407VET6 controller. All very similar to the Seeed Arch Max board as mentioned in my previous post.
I tried doing the mass erase as mentioned in the link you sent me but it did not solve my problem.
PS C:\Users\nljdonk\mbed-os\mbed-os> pyocd erase --mass-erase
0000651:WARNING:board:Generic ‘cortex_m’ target type is selected; is this intentional? You will be able to debug but not program flash. To set the target type use the ‘–target’ argument or ‘target_override’ option. Use ‘pyocd list --targets’ to see available targets types.
0000832:INFO:eraser:Mass erasing device…
0000834:INFO:eraser:Erasing chip…
0000835:INFO:eraser:Done
0000835:INFO:eraser:Successfully erased.
I also noticed, the first time after i formatted my SD card, initializing littlefilesystem gives the following error:
lfs error:494: Corrupted dir pair at 0 1
lfs error:2222: Invalid superblock at 0 1
After a reboot, the error is resolved.
Thanks for the fast reply. Are there some other things you know of that i can try?
I’ll suggest enabling debugging trace to see if it gives you some more information. Check our documentation page for information on how to enable this.
Further, try to use a different SD card if you can in case something is corrupted…
When enabling the debugging trace, the program gets to big for the flash:
Link: mbed-os
c:/program files (x86)/gnu tools arm embedded/6 2017-q2-update/bin/…/lib/gcc/arm-none-eabi/6.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe: ./BUILD/ARCH_MAX/GCC_ARM/mbed-os_application.elf section .text' will not fit in region FLASH’
c:/program files (x86)/gnu tools arm embedded/6 2017-q2-update/bin/…/lib/gcc/arm-none-eabi/6.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe: region `FLASH’ overflowed by 39472 bytes
collect2.exe: error: ld returned 1 exit status
