@Kojto
Thank you Kojto. If I understand you correctly yotta install is used to add dependences not to establish an example project. Hence I when directly to:
https://github.com/ARMmbed/example-mbedos-blinky
C:\FreeScale\mbedos> git clone https://github.com/ARMmbed/example-mbedos-blinky.git
Cloning into ‘example-mbedos-blinky’…
remote: Counting objects: 75, done.
emote: Total 75 (delta 0), reused 0 (delta 0), pack-reused 75
Unpacking objects: 100% (75/75), done.
Checking connectivity… done.
C:\FreeScale\mbedos> cd example-mbedos-blinky
C:\FreeScale\mbedos\example-mbedos-blinky [master]> dir
Directory: C:\FreeScale\mbedos\example-mbedos-blinky
Mode LastWriteTime Length Name
d---- 5/01/2016 2:29 p.m. source
-a— 5/01/2016 2:29 p.m. 140 .gitignore
-a— 5/01/2016 2:29 p.m. 11560 LICENSE
-a— 5/01/2016 2:29 p.m. 581 module.json
-a— 5/01/2016 2:29 p.m. 3090 README.md
C:\FreeScale\mbedos\example-mbedos-blinky [master]> yotta init
info: The current directory already a contains a module: existing description
will be modified
Enter the module name:
Enter the initial version: <1.0.0>
Is this an executable (instead of a re-usable library module)?
Short description: <simple example program to blink an LED on an mbed board
with mbed OS>
Author: kg1
C:\FreeScale\mbedos\example-mbedos-blinky [master +0 ~1 -0]> yotta target
frdm-k64f-gcc
info: get versions for frdm-k64f-gcc
info: download frdm-k64f-gcc@2.0.0 from the public module registry
info: get versions for kinetis-k64-gcc
info: download kinetis-k64-gcc@2.0.0 from the public module registry
info: get versions for mbed-gcc
info: download mbed-gcc@1.1.0 from the public module registry
C:\FreeScale\mbedos\example-mbedos-blinky [master +0 ~1 -0]> yotta build
info: get versions for mbed-drivers
info: download mbed-drivers@0.11.6 from the public module registry
info: get versions for mbed-hal
info: download mbed-hal@1.2.0 from the public module registry
info: get versions for cmsis-core
info: download cmsis-core@1.1.0 from the public module registry
info: get versions for ualloc
info: download ualloc@1.0.3 from the public module registry
info: get versions for minar
info: download minar@1.0.1 from the public module registry
info: get versions for core-util
info: download core-util@1.0.1 from the public module registry
info: get versions for compiler-polyfill
info: download compiler-polyfill@1.2.1 from the public module registry
info: get versions for mbed-hal-freescale
info: download mbed-hal-freescale@1.0.0 from the public module registry
info: get versions for mbed-hal-ksdk-mcu
info: download mbed-hal-ksdk-mcu@1.0.6 from the public module registry
info: get versions for uvisor-lib
info: download uvisor-lib@1.0.11 from the public module registry
info: get versions for mbed-hal-k64f
info: download mbed-hal-k64f@1.0.1 from the public module registry
info: get versions for cmsis-core-freescale
info: download cmsis-core-freescale@1.0.0 from the public module registry
info: get versions for cmsis-core-k64f
info: download cmsis-core-k64f@1.0.0 from the public module registry
info: get versions for mbed-hal-frdm-k64f
info: download mbed-hal-frdm-k64f@1.0.0 from the public module registry
info: get versions for dlmalloc
info: download dlmalloc@1.0.0 from the public module registry
info: get versions for minar-platform
info: download minar-platform@1.0.0 from the public module registry
info: get versions for minar-platform-mbed
info: download minar-platform-mbed@1.0.0 from the public module registry
info: generate for target: frdm-k64f-gcc 2.0.0 at C:\FreeScale\mbedos
\example-mbedos-blinky\yotta_targets\frdm-k64f-gcc
GCC version is: 5.2.1
– The ASM compiler identification is GNU
– Found assembler: C:/Program Files (x86)/GNU Tools ARM Embedded/5.2
2015q4/bin/arm-none-eabi-gcc.exe
– Configuring done
– Generating done
– Build files have been written to: C:/FreeScale/mbedos/example-mbedos-
blinky/build/frdm-k64f-gcc
[130/130] Linking CXX executable source/example-mbedos-blinky
C:\FreeScale\mbedos\example-mbedos-blinky [master +0 ~1 -0]> dir
d---- 5/01/2016 2:38 p.m. build
d---- 5/01/2016 2:33 p.m. test
d---- 5/01/2016 2:38 p.m. yotta_modules
d---- 5/01/2016 2:35 p.m. yotta_targets
-a— 5/01/2016 2:35 p.m. 58 .yotta.json
-a— 5/01/2016 2:33 p.m. 594 module.json
C:\FreeScale\mbedos\example-mbedos-blinky [master +0 ~1 -0]> cd C:\FreeScale
\mbedos\example-mbedos-blinky\build\frdm-k64
f-gcc\source
C:\FreeScale\mbedos\example-mbedos-blinky\build\frdm-k64f-gcc\source [master
+0 ~1 -0]> dir
Directory: C:\FreeScale\mbedos\example-mbedos-blinky\build\frdm-k64f-gcc
\source
d---- 5/01/2016 2:38 p.m. CMakeFiles
-a— 5/01/2016 2:38 p.m. 883 CMakeLists.txt
-a— 5/01/2016 2:38 p.m. 961 cmake_install.cmake
-a— 5/01/2016 2:38 p.m. 355 CTestTestfile.cmake
-a— 5/01/2016 2:38 p.m. 685760 example-mbedos-blinky
-a— 5/01/2016 2:38 p.m. 37352 example-mbedos-blinky.bin
-a— 5/01/2016 2:38 p.m. 333729 example-mbedos-blinky.map
