Discuss getting started with yotta
A great place to start is docs.yottabuild.org !
http://yottadocs.mbed.com/ is the address to use now.
Having some trouble confirming my compiler is working. When I try to run arm-none-eabi-gcc it is failing in my windows cmd prompt. I have installed Cmake and ninja, and have Python 2.7.10 (Docs call for Python 2.7.9, but I donāt see why Python 2.7.10 would not work). It seems like yotta installed fine, but I am concerned my compiler is not responding. I made sure to point my path to the compiler bin folder, but no luck running the program. Anyone get this far yet? Running windows 8 64 bit here.
I can say that I have successfully installed Yotta (using the automated py script) on Windows 8 64 bit.
Yotta is freekin awesome its pretty much identical in function to Composer (PHP dependence manager) which is a compliment as composer is amazing!
Hopefully the Yotta site (http://yotta.mbed.com/) will allow people to add their own packages soon like packagist (PHP https://packagist.org/).
My only complaint would be that Yotta required Python.
Personally I think Iām going to create a Vagrant development environment so I donāt have to install all Yottaās dependants on my local machine.
If any of you guys want me to make a video on installing Yotta thatās not a problem just give us a shout ![]()
Iām having issues with the stock example listed here:
I am attempting to compile from Windows. When I get to the build stage for either the application from scratch or the clone-from-repo one, it fails at [9/130] and precedes with the following error:
C:/path/to/example-mbedos-blinky/yotta_modules/mbed-hal-ksdk-mcu/mbed-hal-ksdk-mcu/objects.h:22:22: fatal error: PinNames.h: No such file or directory
Any thoughts? I can provide my build tools versions as well.
@Androidian072, I created tracking issue, thanks for reporting, I noticed similar issue in another repository.
I ran yotta update on the example and it compiles now. It did complain about something not meeting the specification required by minar, but that seems to be a separate issue.
Having a similar issue when building, with the compilation terminating as it cannot find these headersā¦
#include āuvisor-lib/uvisor-lib.hā
#include ācmsis-core/cmsis_nvic.hā
#include āmbed-alloc/ualloc.hā
Any ideas what could be wrong?
[8/128] Building C object ym/ualloc/source/CMakeFiles/ualloc.dir/ualloc.c.o
error: command ['ninja'] failed
FAILED: C:\PROGRA~2\GNUTOO~1\4636A~1.920\bin\AR10B2~1.EXE -fno-exceptions -fno-unwind-tables -ffunction-sections -fdata-sections -Wall -Wextra -fno-rtti -fno-threadsafe-statics -mcpu=cortex-m4 -mthumb -D__thumb2__ -Os -g -gdwarf-3 -DNDEBUG -DTOOLCHAIN_GCC -DTOOLCHAIN_GCC_ARM -DMBED_OPERATORS -DCPU_MK64FN1M0VMD12 -DTARGET_K64F -include "C:/Users/user/workspace/Blinky/build/frdm-k64f-gcc/yotta_config.h" -MMD -MT ym/uvisor-lib/source/CMakeFiles/uvisor-lib.dir/error.cpp.o -MF ym/uvisor-lib/source/CMakeFiles/uvisor-lib.dir/error.cpp.o.d -o ym/uvisor-lib/source/CMakeFiles/uvisor-lib.dir/error.cpp.o -c C:/Users/user/workspace/Blinky/yotta_modules/uvisor-lib/source/error.cpp
C:/Users/user/workspace/Blinky/yotta_modules/uvisor-lib/source/error.cpp:17:35: fatal error: uvisor-lib/uvisor-lib.h: No such file or directory
#include "uvisor-lib/uvisor-lib.h"
Not easy to buildā¦
Always error
ninja: build stopped: subcommand failed.
Just trying to build the Blinky example, it will build using the tool installed by the automated installer but I would like to be able to automate the build process in an IDE using the command line tools.
Iāve moved the example project to C:/blink and still get an identical error!
@SamKent It looks like the include paths are completely missing from your command line. To debug this it would be helpful to see your ./build/<targetname>/build.ninja and ./build/<targetname>/rules.ninja files. (If you arenāt able to upload here, please open an issue at https://github.com/ARMmbed/yotta/issues/new, where you should be able to attach files.)
Just to confirm a few other things:
- Did you install using the automated installer? (https://github.com/armmbed/yotta_windows_installer)
- what cmake version do you have (
cmake --version)? - what compiler version do you have (
arm-none-eabi-gcc --version)?
Thanks for the reply!
Didnāt use the automated installer, installed manually following the guide. A colleague has an automated install which he can build a project with when going through the tool started by the āRun Yottaā scripts, but canāt build straight from cmd.exe.
build.ninja - https://www.sendspace.com/file/kkeeai
rules.ninja - https://www.sendspace.com/file/t5kzlk
(Github wouldnāt allow me to upload it and threw an error when I uploaded as a .txt)
cmake version 3.4.0-rcl
arm-none-eabi-gcc 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288]
OK ā thatās to be expected. The intention with the installer is that it doesnāt pollute your system path, so to have the paths set up correctly you have to start through the run-yotta script (or source that script from an existing terminal).
From the .ninja files it looks like CMake is setting the includes correctly, but ninja hasnāt propagated them to the compiler invocation command line ā what ninja version are you using (ninja --version)?
Ninja 1.5.3
So if Iām setting up a build in Eclipse should I also download the installer and run the .bat files as part of my build command?
Yeah, thatād be the easiest way to do it.
@SamKent It looks like your problem is caused by using CMake 3.4 ā weāre working on understanding why exactly this breaks things, but for the mean time could you try using an earlier CMake version?
Builds! Great, thanks
