771
(dennis 77)
April 8, 2016, 9:05am
#1
When I import a mbedOS project to Keil MDK, after Yotta2MDK ,and build in the keil IDE .
some errors appered :
Build Project ‘mbed-hal-k64f’ - Target ‘MK64FN1M Flash’
linking…
.\Output\mbed-hal-k64f\mbed-hal-k64f.axf: error: L6002U: Could not open file .\Output\mbed-drivers\mbed-drivers.lib: No such file or directory
Finished: 0 information, 0 warning, 0 error and 1 fatal error messages.
“.\Output\mbed-hal-k64f\mbed-hal-k64f.axf” - 1 Error(s), 0 Warning(s).
Target not created.
Build Time Elapsed: 00:00:01
where is the mbed-drivers.lib ? how can I make it ?
Matthias
(Matthias Hertel)
April 11, 2016, 8:23am
#3
Hello Dennis,
does the project successfully build on yotta? Can you provide the yotta target xxx command you used to set up the build environment?
Matthias
BTW: It is pretty import that you open the generated Multiproject Workspace and Batch build all the projects in it.
771
(dennis 77)
April 11, 2016, 9:26am
#4
The project successfully built on Yotta.
the Yotta target command is :
Yotta2MDK E:\yottapath\k64farmcc frdm-k64f-armcc E:\keilpath\keilproject
after that , there is a keil project generated in folder E:\keilpath\keilproject
include “k64farmcc.uvmpw”.
771
(dennis 77)
April 11, 2016, 9:32am
#5
the yotta commands list is :
yt init
yt target frdm-k64f-armcc
yotta install mbed-drivers
---------------------- the /source/app.cpp is blinky demo
yt build
then , I can find the .bin&.hex files in \build\frdm-k64f-armcc\source path.
so ,I think the project built successfully on Yotta .
771
(dennis 77)
April 12, 2016, 9:03am
#6
mixed compile options can’t support the C++11. We found the reason .
I am waiting for new tools .
thanks Matthias!
maiorfi
(Lorenzo Maiorfi)
April 28, 2016, 11:10am
#7
Hi Matthias.
I used your amazing tool some time ago and it worked a treat.
Recently I had the chanche to use it once more but it seems out of sync with yotta generated folder structure and or with yotta modules. Other than setting --cpp11 option it looks like several files miss, and merging yotta provided ones into uvision project folder causes several other linker problems (specifically unresolved mem alloc functions).
Are you going to publish an updated version of your tool?
Thanks!
brody
(brody tyler)
December 27, 2016, 9:01am
#8
Hi dennis 77.
Can you tell me where to dowload the Yotta2MDK_Setup.exe?
Thank you very much.
I have no idea where it can currently be downloaded, but I had the file on my hard drive. Re-uploaded here: yotta2mdk_Setup.exe .
