I’ve just installed MBed Studio 0.8.1, which is working well with blinky example on NXP LPCXpresso 54114 evaluation board.
I’m trying to run FFT examples using CMSIS-DSP library, but some .directives in the single assembly file arm_bitreversal2.S in the library are confusing the Studio.
https://arm-software.github.io/CMSIS_5/DSP/html/group__FrequencyBin.html
The compiler dislikes the dot-directives :
#elif defined (GNUC) // GCC
#define THUMB .thumb
#define CODESECT .section .text
#define EXPORT .global
.syntax unified
The latest CMSIS-DSP I can find for mbed is 1.5.0 - looks like the .S assembly was converted to .C in 1.5.3 and above but I don’t see where to get a more current DSP library. It’s presently up to 1.7.0
Issue also noted by someone else two years ago - Trying to use CMSIS-DSP with mbed-os... | Mbed
