ANY program I import will not compile and ALL give a Compiler Error 230
Is there a problem with the OS or am I doing something wrong?
I updated everything I could but still get the same error.
I’m not aware of any system wide issues. Please specify what program you’re trying to import, and on what board. Are you using the online compiler or offline compiler?
Lin, team Mbed
Thank you for the concern,
I’m using the online compiler with a Nucleo F767ZI.
If I write a simple program like a binky, it will compile
and run OK.
If I import ANY program like:
I2C_scanner
I2c_SSD1306_Helloworld_WIZwiki-W7500
I2CTextLCD
PCF8574_Helloworld
OR any program less a very simple binky I get a Compiler Error 230
Thank you!
The I2C_scanner is an old Mbed 2 program. I recommend you migrate this to Mbed OS 5. https://os.mbed.com/docs/mbed-os/v5.9/tutorials/migrating.html. I tried migration with Mbed CLI, I was able to build.
Lin, team Mbed
