I tried to compile code for Nucleo F042K6 with Keil Studio and MBED OS 5.10, 5.14 and 5.15 and the output console indicates that “Target does not support mbed OS 5” while it seems compatible on the Nucleo F042K6 overview (NUCLEO-F042K6 | Mbed).
Does someone have a solution to compile on Nucleo F042K6 ?
is can be but because it is very low memory target (32 KB Flash, 6 KB SRAM) then it is not able to run full profile so you should set baremetal profile.
You have to create a file called mbed_app.json in your project folder and place inside settings from this page under section 1. point 4. Then reactivate your project in Keil Studio and should be fine.
Thanks for your help.
I used mbed OS 5.15 and added mbed_app.json file with the following code and it’s working properly: { “requires”: [“bare-metal”] }
