After installing the yotta tools a bunch of times on a few computers, I ran into an issue on a new install. Seems I can’t do anything, because the pyasn1 library isn’t installed (or up to date).
[ericfoss@charlie blinky]$ sudo yotta search mbed
Fatal Exception, yotta=unknown
File "/bin/yotta", line 4, in <module>
yotta.main()
File "/usr/lib/python2.7/site-packages/yotta/main.py", line 205, in main
status = args.command(args, following_args)
File "/usr/lib/python2.7/site-packages/yotta/search.py", line 125, in execCommand
for result in itertools.islice(registry_access.search(query=args.query, keywords=args.kw, registry=args.registry), args.limit):
File "/usr/lib/python2.7/site-packages/yotta/lib/registry_access.py", line 683, in search
headers = _headersForRegistry(registry)
File "/usr/lib/python2.7/site-packages/yotta/lib/registry_access.py", line 414, in _headersForRegistry
'X-Yotta-Client-Version': _getYottaVersion(),
File "/usr/lib/python2.7/site-packages/yotta/lib/registry_access.py", line 397, in _getYottaVersion
_yotta_version = pkg_resources.require("yotta")[0].version
File "/usr/lib/python2.7/site-packages/pkg_resources.py", line 664, in require
needed = self.resolve(parse_requirements(requirements))
File "/usr/lib/python2.7/site-packages/pkg_resources.py", line 571, in resolve
raise VersionConflict(dist,req) # XXX put more info here
pkg_resources.VersionConflict: (pyasn1 0.1.7 (/usr/lib/python2.7/site-packages), Requirement.parse('pyasn1>=0.1.8'))
A quick search told me to run
sudo pip install pyasn1 --upgrade
Which I did and it now works. Could this be missing from the install instructions?
