Hello, I am trying to import DSP in my project to use arm_math features but I am stuck with no idea how to continue.
- Git clone CMSIS_5-develop
- Edit cmsis_importer.json, I have added DSP in the last two folders to include
"files" : [
"src_file" : "CMSIS/Core/Template/ARMv8-M/tz_context.c",
"dest_file" : "cmsis/CMSIS_5/CMSIS/TARGET_CORTEX_M/Source/mbed_tz_context.c"
"src_file" : "CMSIS/RTOS2/RTX/Config/handlers.c",
"dest_file" : "cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Config/TARGET_CORTEX_A/handlers.c"
"src_file" : "CMSIS/RTOS2/RTX/Config/RTX_Config.h",
"dest_file" : "cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Config/RTX_Config.h"
"src_file" : "CMSIS/RTOS2/RTX/Config/RTX_Config.c",
"dest_file" : "cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Config/RTX_Config.c"
"src_file" : "CMSIS/RTOS2/RTX/Source/ARM/irq_armv6m.s",
"dest_file" : "cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Source/TOOLCHAIN_ARM/TARGET_M0/irq_cm0.S"
"dest_file" : "cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Source/TOOLCHAIN_ARM/TARGET_M0P/irq_cm0.S"
"src_file" : "CMSIS/RTOS2/RTX/Source/ARM/irq_armv8mbl.s",
"dest_file" : "cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Source/TOOLCHAIN_ARM/TARGET_M23/irq_armv8mbl.S"
"src_file" : "CMSIS/RTOS2/RTX/Source/ARM/irq_armv7m.s",
"dest_file" : "cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Source/TOOLCHAIN_ARM/TARGET_M3/irq_cm3.S"
"src_file" : "CMSIS/RTOS2/RTX/Source/ARM/irq_armv8mml.s",
"dest_file" : "cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Source/TOOLCHAIN_ARM/TARGET_M33/irq_armv8mml.S"
"dest_file" : "cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Source/TOOLCHAIN_ARM/TARGET_RTOS_M4_M7/irq_cm4f.S"
"src_file" : "CMSIS/RTOS2/RTX/Source/ARM/irq_armv7a.s",
"dest_file" : "cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Source/TOOLCHAIN_ARM/TARGET_CORTEX_A/irq_ca.S"
"src_file" : "CMSIS/RTOS2/RTX/Source/GCC/irq_armv6m.S",
"dest_file" : "cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Source/TOOLCHAIN_GCC/TARGET_M0/irq_cm0.S"
"dest_file" : "cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Source/TOOLCHAIN_GCC/TARGET_M0P/irq_cm0.S"
"src_file" : "CMSIS/RTOS2/RTX/Source/GCC/irq_armv8mbl.S",
"dest_file" : "cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Source/TOOLCHAIN_GCC/TARGET_M23/irq_armv8mbl.S"
"src_file" : "CMSIS/RTOS2/RTX/Source/GCC/irq_armv7m.S",
"dest_file" : "cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Source/TOOLCHAIN_GCC/TARGET_M3/irq_cm3.S"
"src_file" : "CMSIS/RTOS2/RTX/Source/GCC/irq_armv8mml.S",
"dest_file" : "cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Source/TOOLCHAIN_GCC/TARGET_M33/irq_armv8mml.S"
"dest_file" : "cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Source/TOOLCHAIN_GCC/TARGET_RTOS_M4_M7/irq_cm4f.S"
"src_file" : "CMSIS/RTOS2/RTX/Source/GCC/irq_armv7a.S",
"dest_file" : "cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Source/TOOLCHAIN_GCC/TARGET_CORTEX_A/irq_ca.S"
"src_file" : "CMSIS/RTOS2/RTX/Source/IAR/irq_armv6m.s",
"dest_file" : "cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Source/TOOLCHAIN_IAR/TARGET_M0/irq_cm0.S"
"dest_file" : "cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Source/TOOLCHAIN_IAR/TARGET_M0P/irq_cm0.S"
"src_file" : "CMSIS/RTOS2/RTX/Source/IAR/irq_armv8mbl.s",
"dest_file" : "cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Source/TOOLCHAIN_IAR/TARGET_M23/irq_armv8mbl_common.S"
"src_file" : "CMSIS/RTOS2/RTX/Source/IAR/irq_armv7m.s",
"dest_file" : "cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Source/TOOLCHAIN_IAR/TARGET_M3/irq_cm3.S"
"src_file" : "CMSIS/RTOS2/RTX/Source/IAR/irq_armv8mml.s",
"dest_file" : "cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Source/TOOLCHAIN_IAR/TARGET_M33/irq_armv8mml_common.S"
"dest_file" : "cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Source/TOOLCHAIN_IAR/TARGET_RTOS_M4_M7/irq_cm4f.S"
"src_file" : "CMSIS/RTOS2/Source/os_systick.c",
"dest_file" : "cmsis/CMSIS_5/CMSIS/RTOS2/Source/os_systick.c"
"src_file" : "CMSIS/RTOS2/RTX/Source/IAR/irq_armv7a.s",
"dest_file" : "cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Source/TOOLCHAIN_IAR/TARGET_CORTEX_A/irq_ca.S"
"src_file" : "CMSIS/RTOS2/RTX/Library/cmsis_os1.c",
"dest_file" : "cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Library/cmsis_os1.c"
"folders" : [
"src_folder" : "CMSIS/Core/Include/",
"dest_folder" : "cmsis/CMSIS_5/CMSIS/TARGET_CORTEX_M/Include"
"src_folder" : "CMSIS/RTOS2/Include/",
"dest_folder" : "cmsis/CMSIS_5/CMSIS/RTOS2/Include/"
"src_folder" : "CMSIS/RTOS2/RTX/Include1/",
"dest_folder" : "cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Include1/"
"src_folder" : "CMSIS/RTOS2/RTX/Include/",
"dest_folder" : "cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Include/"
"src_folder" : "CMSIS/RTOS2/RTX/Source/",
"dest_folder" : "cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Source/"
"src_folder" : "CMSIS/Core_A/Include/",
"dest_folder" : "cmsis/CMSIS_5/CMSIS/TARGET_CORTEX_A/Include/"
"src_folder" : "CMSIS/Core_A/Source/",
"dest_folder" : "cmsis/CMSIS_5/CMSIS/TARGET_CORTEX_A/Source/"
"src_folder" : "CMSIS/DSP/Include/",
"dest_folder" : "cmsis/CMSIS_5/CMSIS/DSP/Include/"
"src_folder" : "CMSIS/DSP/Source/",
"dest_folder" : "cmsis/CMSIS_5/CMSIS/DSP/Source/"
"commit_sha" : [
"4360b7bbf815c4d812005938c9c27af199803a97",
"fb354752eb69403ad503c8e53da67da6483776d6",
"08ab8cc47d8722bf0c767990cd615cf1c427d006",
"00580ce3f5d64b76342b7f26deed55e842056ea0",
"c122158d496d59fbd723bdb17bbc7bd5cc95245e"
Remove commit _sha
43a86f30450f8e9cec366434f6f752430847b4cfbecause
Response :The command git cherry-pick -x 43a86f30450f8e9cec366434f6f752430847b4cf failed with return code: 128 -
run
python tools\importer\importer.py -c tools\importer\cmsis_importer.json -r ..\CMSIS_5-develop\Response :
Already on 'feature_CMSIS_5-develop_fd9c719
Nothing has changed in the mbed-os/cmsis directory. Is there any problem with my steps?
