Keil Studio isn’t loading, or rather it is stuck in loading resources.
When will it work again?
I don’t know what a state was an hour ago, but it is Ok right now.
Now at least the compiler loads, but…
The state for me now is that if I do any changes to the main tree, I need to reload the page compared to how it was that the change was visible right away.
BR
Johan
Also loading a new mbed-os ref lib doesn’t change the lib, or does it?
It still says "mbed- os 6.12.0 even though I’ve changed it to an earlier lib.
BR
Johan
Hi Johan,
There are occasions when the Explorer tree in KSC fails to represent the true state of the file system in your workspace. This is a known issue and the Keil Studio team are investigating it.
For now reload the page when this occurs. Hopefully it won’t be long before there is a fix for it.
Kanthan
Hi Johan,
Using KSC version 1.5.51 I have just attempted to change the mbed-os version for Blinky example project from 6.16.0 to 6.12.0 to 6.5.0. It works fine for me.
Are you using the Change Library version from the Mbed Libraries view?
If not and you can’t see the Mbed Libraries view at the bottom of the page you can access it from the View menu
Kanthan
If you have any other observations / issues please raise them as separate forum posts.
Kanthan
Thanks for the answer and possible options to fix this problem.
