MAX78000 feather board - not possible to flash code in Eclipse MaximSDK
I am following MAX78000 feather board tutorials to upload example code using Eclipse Maxim SDK. But I receive launch failed error. I had disabled the firewall and relaunched the IDE and tried just to see if the ports are blocked by firewall. But that did not work. Kindly help how to solve this problem.
Error in final launch sequence
Failed to execute MI command:
-target-select remote localhost:3333
Error message from debugger back end:
localhost:3333: No connection could be made because the target machine actively refused it.
MAX78000 seems not to be Mbed enabled board - Development boards | Mbed.
This doesn’t seem to be an Mbed related issue. Maybe you may to ask about it on a community or on a support of Maxim’s website.
