I’ve been looking for more since I posted this question a while ago.
There is also a void function, so I put it in, but I get this error.
I still don’t know what to do.
Do you know anyone?
to be honest the problem description was not made very well. There is not visible any error just a code what is commented out and another code what seems like it have nothing together with rest in perspective of objects, because getRssi() is method of AdvertisingReportEvents.
getRssi()
- mbed-os/Events.h at c358ab294628e297481c5fd1f737ebbaadef87a6 · ARMmbed/mbed-os · GitHub
Moreover probably this topic was placed to wrong section of the forum, because I believe this is not related to KeilStudio, but insted to Mbed OS. Also an info about used MbedOS version is missing.
Looking at the mbed-os code you linked, it is mbed-os.lib that I am using.
But what if I want to use mbed-os/connectivity/FEATURE_BLE/include/ble/gap/Events.h ?
I know what the problem is.
I am using mbed-os version 5.1.4, 5.1.4 does not have ble/gap/Events.h.
Events.h exists in the master version and has a getRssi() function, but
When I change the version to master I get a build error.
To use the getRssi() function, I must use a higher version, but a build error occurs and I cannot do it.
you’re spinning in circle
- Import from Mbed error - Keil Studio - Arm Mbed OS support forum
- Bin file generated by keil - Keil Studio - Arm Mbed OS support forum
Try to switch to 5.15 and then downgrade 5.14, 5.13, 5.12 and so on, until you found a working one.
